jrhop
Message 1 of 4
Remote codes for TCL 32ES568 Android TV
Hello,
I am trying to set up my YouView remote to control my TCL TV, I have used this same YouView box on a Samsung TV, which worked fine. I have used the guide here and it accepts the 3285 code for TCL, but holding down the TV on/off button for a minute or two does nothing. I have also tried pressing OK after it accepts the code, as some have said on other posts, but doesn't seem to work.
I have the box and remote shown here - https://www.bt.com/help/tv/fix-a-problem/remote-control/how-do-i-control-my-tv-with-my-bt-tv-remote-...
I have read on some other posts that other companies make TVs on behalf of other companies and it could be there codes, any idea who might make TCL TVs? The TV is a TCL 32ES568 Android TV.
Thanks in advance.
3 REPLIES 3
Les-Gibson
Message 2 of 4
Re: Remote codes for TCL 32ES568 Android TV
According to https://www.facebook.com/universalremotecode/posts/tcl-codes3-digit-codes645-535-551-666-650-601-824...
it could be any of these (or maybe none), you'll just have to try them and see if one works
3649 2675 0625 2530 0806 1916 0698 0706 0587 0412 3047 4398 3183 2958 3971 2851 0091 1421 1691 1851 2011 2061 2111 2301 3421 3431 3571 4921 5961 6031 5771 6171 6201
♪♪I don't work for BT, I offer my time and help for free. If you'd like to leave a kudo, you may do so by clicking the rating button below.♪♪ 😄
jrhop
Message 3 of 4
Thanks for replying, those didn’t work unfortunately. I have managed to get it working using a Thompson code, 0662, read another post that TCL bought Thompson. So on/off works and volume, input/source works but you can’t use youview remote to press up/down to change. That I can live with. When I went through the process it did take a minute or two before it turned off the TV.
PaddyB
Moderator
Moderator
Message 4 of 4
Hi @jrhop,
Thank you for posting back to update the thread, that information will be really useful for anyone else that might find themself in the same position.
Paddy
