ywu
Message 1 of 7
Remote control clashes with Apple TV
Anyone find that their BT remote also controls the Apple TV? It's not really a benefit to me as I can't change inputs with it, so what I find when I change over to use the Apple TV, the menu selections are all over the place.
6 REPLIES 6
Distinguished Guru
Message 2 of 7
Re: Remote control clashes with Apple TV
It certainly doesn't clash with my Apple TV
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
ywu
Message 3 of 7
I should mention it's a 2nd Gen. Really odd, it's def happening, I'm pausing, stopping, navigate, the YouView button acts as the menu button!
Distinguished Guru
Message 4 of 7
Don't you leave your Apple TV in sleep mode
Helpful Post?
ywu
Message 5 of 7
Yes, but only to timeout into it. So if I switch between viewing modes, it'll be affected during that window. Also, pressing ok is enough to wake it anyway.
GarethW
Expert
Message 6 of 7
You can programme any remote to control your Apple TV, someone must have done this with your BT remote. Go to the settings in your Apple TV menu, you can probably disassociate it, I can't check at the minute.
ywu
Message 7 of 7
Ah, that's it, thank you. The remote was previously set up with the Humax HDR-FOX-T2! All fine now.
