Newbie
Message 1 of 6
Remote control sticking on fast forward and rewind when watching live tv
Hi, when I am watching live tv, if I try to rewind to a few minutes to rewatch something, my remote keeps rewinding until it gets to when I started to watch the programme. The only way I can stop it is if I press the pause or change the channel. The same thing is happening when I fast forward.  I have asked BT help and their answer was to send me a new remote which is doing the same thing as the old one. I have just done an online chat with them tonight and they are going to send me yet another remote. I'm not sure the remote is the problem, though as I'm not technically minded I could be wrong, but has anyone else had this problem and found a solution? Thanks
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: Remote control sticking on fast forward and rewind when watching live tv
Hi @pennyjs Sorry your are experiencing a problem with your BTTV service.
Have you noticed any other issues with your BTTV box not responding to the remote control. Check out My BT TV remote control isn't working as this contains some helpful advice and as you have already had a replacement remote control it could be that a reset of the BTTV box may resolve this. Post back and let us know how you get on.
Cheers
John
Newbie
Message 3 of 6
Hi John
The factory reset seems to have solved the problem, it has also done an update that hadn't happened.
Moderator
Moderator
Message 4 of 6
@pennyjs wrote:
Hi John
Great to see you managed to get this sorted out @pennyjs  Smiley Happy
Message 5 of 6
I’m having the same problem. It’s definitely not the remote. I’ve also noticed that the skip forward/backward options don’t work when I’ve paused live TV
Message 6 of 6
I'm having exactly this issue currently, looks like a factory reset is in order. Does that mean I lose any recordings that I have on the disk?
