NigelB72
Message 1 of 5
Remote control
Some of the buttons on the remote control are a bit temperamental after 2 years and need a solid stab to work. Does anybody know how I can get a new twanger please?
Tags (1)
4 REPLIES 4
Message 2 of 5
Re: Remote control
BT Shop
http://www.shop.bt.com/products/bt-youview---remote-control-080440-9CYZ.html?q=youview%20remote%20co...
If you are happy to carefully dismantle the existing remote control, you will find a printed circuit keypad area.
If you clean that with an alcohol wipe, or Servisol contact cleaner, you should fing that it works as good as new.
NigelB72
Message 3 of 5
Re: Remote control
Thanks for the speedy response.. I'll take the easy option and buy one.. ta
Message 4 of 5
Re: Remote control
You could still fix the old one and keep it as a spare, you would have nothing to loose. If you fancy a challenge, just make sure you don`t spill the buttons everywhere by keeping the front pointing down when you separate the two sections Smiley Wink
NigelB72
Message 5 of 5
Re: Remote control
I'll give it a go when my new one arrives 👍
