Spewy
Message 1 of 4
Remote control
I have read all the the relevent posts and links for remote control issues but cant find a solution to my particualr issue.
My remote control was working fine including switching tv/av and volume control for tv, siddendly thsi stopped working and i called support and was issued a new remote.
This didnt work so they sent me a new box and remote control, same thing it didn't work, called again and had a third remote control sent out. Same again it doesn't work properly.
To be clear the basic functions are possible with the remote ie - changing channel, tv guide, BT player buttons etc but they are intermittent i have to press the buttons numerous times at various angles, but the volume and tv/av - nothing.
Any help would be very much appreciated.
3 REPLIES 3
srpsrp
Expert
Message 2 of 4
Re: Remote control
Check for remote extenders or remote controls stuck under the sofa that are transmitting. You can only use one IR remote at a time. Also it has been known in other forums for plasma TVs to interfere with remote controls.
Spewy
Message 3 of 4
Re: Remote control
Thanks, the other remote in use is exactly what it is like but unfortunately not the solution in this case.
srpsrp
Expert
Message 4 of 4
Re: Remote control
it seems rather unlikely to me that you have tried 3 faulty remote controls and 2 faulty boxes, can you take the box to a TV in another room and try it there ?
