Defleppard62
Message 1 of 4
Remote record button won’t work. Why?
3 REPLIES 3
Devon_Dave
Distinguished Guru
Message 2 of 4
Re: Remote record button won’t work. Why?
Are you using the youview app to set recordings?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Andy005
Recognised Expert
Message 3 of 4
It hasn't worked for well over two weeks, a similar post here:
https://community.bt.com/t5/YouView-from-BT/Cannot-remote-record/td-p/1879883
You would expect that as BT are aware of the bug that they would do something about it Smiley Wink
zulu17
Distinguished Guru
Distinguished Guru
Message 4 of 4
@Defleppard62 Can you confirm wherever it is the remote control Record button on your Youview remote that is not working as you expect OR the  process of using a phone/tablet and the Youview or BT TV app to select programmes for recording whilst you are in a remote location ?
