AjayK46
Message 1 of 11
Replacement Remote Control for BT Youview Box Humax DTRT2100
I need a new remote for my DTRT2100 but can't find one that looks the same. Any help appreciated as to what will be compatible much appreciated. Thank you.
10 REPLIES 10
Message 2 of 11
Re: Replacement Remote Control for BT Youview Box Humax DTRT2100
See https://www.shop.bt.com/products/bt-youview--remote-control-080440-9CYZ.html
AjayK46
Message 3 of 11
Thank you. That one is long term out of stock. Would any others be compatible?
Message 4 of 11
Have you asked on BT TV live chat to see if they can supply a replacement?
There are also third party sellers on Amazon and ebay.
If its just some buttons not working, then taking it apart and cleaning the contact area with some isoppropyl alcohol wipes, often fixes the problem.
AjayK46
Message 5 of 11
Thank you. Rather nervously managed to take it apart and clean. All now working.
Message 6 of 11
It usually works, as it just oxidisation caused by holding it with your hands. Its a bit fiddly, but  it saves money :smileyhappy:
gomezz
Recognised Expert
Message 7 of 11
Treat it as an opportunity to get yourself a late Christmas present and get a Harmony universal remote control. Their 650 model is one I can recommend or one of their more expensive models.
fixcontrol
Newbie
Message 8 of 11
Thank you I think I may do that..
fixcontrol
Newbie
Message 9 of 11
Hi I think I might buy a replacement from Amazon or Ebay..Thanks
Message 10 of 11
Dismantling and cleaning it out, is not difficult, you would be surprised how much dirt gets inside.
