Notplastic
Newbie
Message 1 of 12
Reset Youview Remote control
I have tried setting the rremote for my youview to my TV and want reset it back to the factory settings.  How do I do this?
11 REPLIES 11
BT TV Expert
BT TV Expert
Message 2 of 12
Re: Reset Youview Remote control
Hi Notplastic,
You need to hold the 'TV' button and Red coloured button for a few seconds until the 'PVR' button flashes red 3 times.
Steve
BT TV expertSteveM
Show your appreciation!
Kudos”Kudos”
I am a BT Employee and an expert on TV queries. I am here volunteering my own time to give advice, and help where I can with BTTV queries. Go here for more info.
Notplastic
Newbie
Message 3 of 12
There is no TV button on my remote. I have Zoom Power Help - Youview BTVision - Search Guide Text - Red Green Yellow Blue.  But no TV.
BT TV Expert
BT TV Expert
Message 4 of 12
Doh!
In that case, use the Power, AD & Sub buttons
Steve
BT TV expertSteveM
Kudos”Kudos”
Notplastic
Newbie
Message 5 of 12
Brill
Cheers
JohnO67
Newbie
Message 6 of 12
Hello - held down TV and red button and nothing happens. I'm trying to reset as the sound is too low on my TV now that I've set TV to work of youview remote.
jaimandal
Message 7 of 12
Press ADD, SUB (which is the left and right button of 0) and Power together for about 5 second's and that's done.
Thanks & Regards.
Jai P Mandal △
SiCo
Message 8 of 12
you could also go to settings, TV Signal & Quality, and scroll up to HDMI Audio Format, and change this to Surround. This should set the volume on the Youview box to maximum, and then you won't need to program the remote to your TV again.
Ptull3
Newbie
Message 9 of 12
Hi there
I have a 2006 Panasonic and can't get the bt you view remote to work properly. I've gone through using the right code which will allow the tv to switch off but that's as far as it goes. The tv will not power up from the remote and the volume buttons refuse to work. Any ideas welcome please.
elaine5757
Newbie
Message 10 of 12
I have tried this and it has had no effect.Is there anything else i could try?
