steviejay
Message 1 of 19
Restart recording does not work
BT Humax DTR-T2100
Remote Control RC3124705/02B
Basically, the option to restart a recording from the beginning doesn't work. When you hold down 'OK' the timer doesn't count the whole way down from 3, it stops as if the remote has been released, yet it hasn't. Anyone else had this?
I've reset the box and the remote and it still happens.
Software version 31.69.0
Component version 3.5.132
I will add that I have two other Huawei boxes that have the same software updates and two different remotes that will complete this particular operation. If the Humax wasn't so much faster when it does work, I would just replace it.
I think I'll try replacing the remote.
18 REPLIES 18
Distinguished Guru
Distinguished Guru
Message 2 of 19
Re: Restart recording does not work
There is an OK button on the top of that Youview box, so you could see what happens if you hold that rather than the remote Ok button.
steviejay
Message 3 of 19
It does not respond to the OK button in that context. It was a good idea, perhaps someone with a working remote could confirm their top button does not respond.
I can't try it on the Huawei devices as they have only Power and -/+
nostra999
Message 4 of 19
Hey can confirm it works fine for me on a UHD box
steviejay
Message 5 of 19
Thanks, but to be fair that's different hardware with different software versions.
BT DB-T2100 / 84B08500 31.69.0 / 3.5.132
BT DTR-T4000 / 87B08500 31.108.0 / 3.5.136
nostra999
Message 6 of 19
Also tested working on a t2100 upstairs.
Running 3.5.132
steviejay
Message 7 of 19
To be clear, this is using the OK button on top of the set top box, not the remote. (The remote will not complete the operation and the OK button on the set top box does not work in this context - it does work for other functions tested).
I appreciate your efforts but unfortunately your replies are slightly ambiguous, sorry for seeking clarification.
nostra999
Message 8 of 19
No from your initial post it appeared you were referring to the remote.
Holding ok on the box for me does not restart recording pressing with remote does.
Hope that helps.
steviejay
Message 9 of 19
That does help, thank you.
steviejay
Message 10 of 19
Seems this is a box or software problem. Exactly the same issue with a brand new remote although the newest remote has a nicer action and possibly a better (less directional) IR blast.
