PaulinePeake
Message 1 of 5
Retuning TV - Error Code 302
I am getting error code: YVM302 on my TV. I have been told that in order to fix it I need to re-tune my box and the procedure is: Click Home.
Goto Settings
Goto TV Channels
Click Re-tune TV.
I have pressed home and the following options appear: Guide. Apps. MyTV. BTPlayer. TV Shows. Films.
Does anyone know where the settings option is?
Many thanks,
Pauline
4 REPLIES 4
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 5
Re: Retuning TV - Error Code 302
Settings is the cog symbol at the top on that screen next to the help ? and time.
PaulinePeake
Message 3 of 5
Is that the screen which comes up, when I press BT Player?
NeilO
Moderator
Moderator
Message 4 of 5
Hi @PaulinePeake it's the blue button which is below the BT Player button on the remote.
  1. Press the blue Home (or YouView) button on your remote control
  2. Go to Settings > Signal & Connection
  3. Choose TV Channels, then Retune Channels. The new channels should now appear
TimCurtis
Guru
Message 5 of 5
@PaulinePeake
Note that with the lataest update that settings is now the cog at the top right of the screen and once you've got the line of Guide, My Tv etc showing you need to press the up arrow at the centre of the remote to access settings.
Another one of these changes that they never tell you about and totally confuse the user base.👎
