mikegledholt
Message 1 of 2
Retuning fails to work
Retuning BT humax dtrt1000 fails to change listings. I have retuned 3 times, rebooted once & restarted once. The channel listing still hasn't changed & all I see is "this channel is now on....
1 REPLY 1
mikegledholt
Message 2 of 2
Re: Retuning fails to work
Just discovered that it has worked but the old listings are still there which confused me! I have hidden the old channels to avoid confusion.
