rebnats
Message 11 of 14
Re: STRAIGHT QUESTIONS DESERVES STRAIGHT ANSWERS ...............
It is all very well telephoning BT for straight answers, if you get through to the right department. Some staff will say one thing another will state something else leaving you still in the dark. If you are put through to India, some there have not even heard of youview.
Distinguished Guru
Distinguished Guru
Message 12 of 14
If you want an answer to a direct question why don't you email your question. THat way you have a record of what you asked and the written response.
hitman
Message 13 of 14
It takes them to long to reply ,when you phone them you get passed from department to department ...nobody in india knows anything about youview ....................................
duncansby
Message 14 of 14
Is the . button broken on your keyboard?
