ggmcintosh
Message 1 of 6
STV player
Has anyone else had a problem with the STV player on YouView? I've recently tried to watch Black Work, but it froze, wouldn't rewind, switch itself off meaning going back to the adverts again, and do weird things when pausing (went backwards). Added to the poor picture quality...ended up watching the series on a cruddy old laptop. Everything else about the box is fine, just the stv player.
5 REPLIES 5
Telecom89
Recognised Expert
Message 2 of 6
Re: STV player
Could be a problem with their player app. Is it only this programme? Can you try something else?
Failing that get in touch with STV: http://player.stv.tv/help/#tab-contact-content
Also take a look at: https://community.youview.com/youview and search for: STV player
ggmcintosh
Message 3 of 6
Re: STV player
Tried the third episode today, went fine until 1st set of (tedious) ads. A box appeared saying "there is an error, this programme won't continue" or words to that effect but it was still playing in the background. So what do you do? You press ok and the whole thing stops and you're back to the beginning. I think I'll just stick to making sure I record stuff instead of using catch up.
Telecom89
Recognised Expert
Message 4 of 6
Re: STV player
Not great. If you have a look on the YouView website you'll see you are not alone in this.
Can I suggest that you actually report this error/issue to STV via the link I provided as if nobody reports this to them they won't fix it.
ggmcintosh
Message 5 of 6
Re: STV player
Yep, doing that now. I only used the player cos I got fed up with recordings on stv finishing early! But that's another story...
davidrsim
Message 6 of 6
Re: STV player
Yes, same problem here. Unable to restart the programme without watching 12 mins of ads!
