Message 1 of 2
Samsung tv - Remotes have stopped working can’t find code!
Hello, the you view remotes decided to stop working one day with the you view box. I followed the info and code given on the bt website and it didn’t do anything. I searched online and found some other codes for Samsung TVs and none of them work. At best it gave me the opportunity to at least use basic functions on the remote. I am disabled and it is really hard trying to operate the tv this way can anyone please please help me!
It’s a Samsung series 5 UE40J5100AK and it’s the volume, and tv on/off options thank you x
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Samsung tv - Remotes have stopped working can’t find code!
Hi @The-happy-cloud,
Welcome to the community and thank you for posting. Have you tried these steps - Controlling my TV with my BT TV remote?
Looking at the list of codes for Samsung 4483 should work.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
