NigelB72
Message 1 of 11
Scheduled Recordings
Does anyone have a blank scheduled recordings screen when it should be showing all your programmed recordings?? 🤔
10 REPLIES 10
Moderator
Moderator
Message 2 of 11
Re: Scheduled Recordings
Hi @NigelB72
Thanks for your post and welcome back!
Sorry that your scheduled recordings aren't showing.  Have a look at this link for steps on how to perform a factory reset keeping you recordings
(Just choose the box you're using and follow the steps).  Post back and let me know how you get on.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
NigelB72
Message 3 of 11
Thanks for the response Robbie. It occasionally happens. I'll give the factory reset a go in a bit 👍
NigelB72
Message 4 of 11
Did the reset and no joy so it's probably at server issue and will sort itself out... Stuff is still recording so no major issues... 👍
Moderator
Moderator
Message 5 of 11
Do keep me posted @NigelB72
If you do still have problems feel free to post back and we'll look at this for you from here.
Cheers,
Robbie
Kudos”Kudos”
NigelB72
Message 6 of 11
Will do @RobbieMac ... We're getting a UHD TV in a few days, Gemma has already sent me a UHD box due to some issues with Amazon Prime but I've just had a look on MyBT and can't see an option to upgrade to the UHD TV pack.. how do I do this?
TimCurtis
Recognised Expert
Message 7 of 11
@NigelB72
This seems to be an increasingly more common problem, reported both here and over on the Youview forum.
I believe Youview are investigating the reasons for this.
NigelB72
Message 8 of 11
They all came back over night so just a glitch from either Youview or BT servers
WilfH
Message 9 of 11
Hi all,
just had this problem appear last night on my T4000 so mark that up as another instance.
WilfH
WilfH
Message 10 of 11
Just to add to this, both the BT TV app and the official YouView mobile app can still display the scheduled recordings list which is presumably downloaded from the STB so there is clearly an issue with the code in the box which renders the list since the list itself clearly exists and is valid.
WilfH
