gadget_geek
Message 1 of 2
Second BT Youview box set up
Can anyone verify that the following set up would work. Interested in TV Everywhere and I Just want to pay the £5 subscription as I already have another BT Youview box in a second room. Thought I could use power plugs or a Universal WiFi adapter to connect the second box to my hub. Do not like the engineer visit method. I take it then I will be able to access BT Sport and the extrat internet channels on this box.
1 REPLY 1
TimCurtis
Recognised Expert
Message 2 of 2
Re: Second BT Youview box set up
Homeplugs/Powerline adapters should work just fine, wireless no as the hub doesn't support multicast over wireless.
