Message 1 of 5
Second Remote
Can anyone tell me if I can sync a second remote to work with the you view + box. The remote will work for all functions but will not turn the TV off and on. I have tried the code for our TV (LG) code 2992 but the blue light stays on and becomes completely unresponsive until I take the batteries out and start it again. Thank you in advance.
4 REPLIES 4
Recognised Expert
Message 2 of 5
Re: Second Remote
Absolutely no reason why you can't have 2 remotes working.
I've 2 Youview boxes & 2 Panasonic TVs & both Youview remotes work both TVs.
Message 3 of 5
Re: Second Remote
Ok thanks, now I know it could work, do you have any suggestions to how to get it to work?
Message 4 of 5
Re: Second Remote
How did you get your first remote working? If you're following all the same steps, then it can only be a problem with your second remote.
Message 5 of 5
Re: Second Remote
By the way, I've had the same problem before with the newer remotes appearing to 'freeze up' and the light being solid blue. In my case, the instructions for programming it were missing a step to press the 'OK' button.
After you've entered your code, the light on the remote goes solid blue. If you press 'OK' to store your changes at this point, the light goes out, and THEN you can press the TV standby button to turn your TV back on. Then everything should be working.
