Message 1 of 2
Second box
If I order a tv package with the pro box and take the smaller second box, I know you can’t record on the second box but can you watch recordings from the main box on it? Thanks.
1 REPLY 1
Message 2 of 2
Re: Second box
No, the boxes don't link up to share recordings.
You might find the programme you like is on catchup though.
