stonedj
Newbie
Message 1 of 2
Setting up youview and weak picture
Hi
I have today installed my youview box after moving into new property. I have connected the youview cable through to aerial box but I am getting a very distorted picture. I have checked all connections but with no joy. I have checked signal and it was about 30% and from what I have read less than 50% is not good.
Can anyone help or advise, could it be the aerial and how can I check whether the roof aerial is up to providing the freeview channels?
Thank you
1 REPLY 1
monarchjock
Message 2 of 2
Re: Setting up youview and weak picture
How far have you moved from your old property? Perhaps you might be receiving your signal from a different transmitter.Try a retune.
