Hi,
I've updated my BT box to include NOW tv programs. Since doing so I have now lost "Settings" in the menu and "TV Shows" and "Films" have appeared. See attached screenshot. It is the latest 4K box about six months old.
Keith
Solved! Go to Solution.
Hi @Syrup
Settings is now the little cog icon in the top right of your screen.
If you press UP when in the menu you have shown you will be able to get to get.
The ? is for help.
Thanks 4K what a lifesaver. I was going to do a factory reset after finding nothing on the internet which would have achieved nothing.
Perhaps the cog seems a bit obvious now but not at the time.
Thank you again
Keith
