DavidCo
Expert
Message 1 of 4
Settings missing on YouView+ box
When I go to Settings> I do not see Information & Reset>Device Information
There are a lot of squares with various descriptions but not that one.
I think I may have an update issue?
3 REPLIES 3
BT TV Expert
BT TV Expert
Message 2 of 4
Re: Settings missing on YouView+ box
The last category heading is "Information & Reset" and the first box is labled "Device Information"
Steve
Community ModeratorSteveM
Show your appreciation!
Kudos”
I am a BT Employee and an expert on TV queries. I am here volunteering my own time to give advice, and help where I can with BTTV queries. Go here for more info.
DavidCo
Expert
Message 3 of 4
Sorry, you are correct.
I still don't have itSmiley Sad
DavidCo
Expert
Message 4 of 4
Sorry, I have now found it!
I went to take a photo and noticed a little horizontal line at the bottom of the screen, kept hitting the 'down arrow' and there it was.
My actual issue was that when we had recorded something and it was repeated it recorded it again. We have not worked out how to stop this.
