dgravy
Message 1 of 2
Should I upgrade 12 month old BT YouView box with new one?
I have an existing BT YouView box from 12 months ago, and have just got a new one as I have taken over the account.
Is there any advantage to me replacing the existing box with the new one?
According to the sticker they are the same model (DB-T2200/BT/DF), model code (91-00537) and item code (078931).
Have they in fact change ove the last year in any way, or will a newer box perform better in any way? Do they deteriorate with use?
Cheers
1 REPLY 1
Distinguished Guru
Distinguished Guru
Message 2 of 2
Re: Should I upgrade 12 month old BT YouView box with new one?
Those are I believe the nonrecordable Youview boxes so I doubt there is any benefit in swapping the boxes particularly if you are happy with its present performance.
