Message 1 of 5
Sky Showcase IPC6012
I have the BT VIP Package.
I was happily watching Sky One this morning which changed to Sky Max, which then disappeared. I now have Sky Showcase on Channeel 355 with error code IPC6012. I  have restarted the router but no change.
At the same time Sky Max has disappeared.
When I look at the TV Channels it states there are 2 streamed channels, Where would I find those?
4 REPLIES 4
Message 2 of 5
Re: Sky Showcase IPC6012
Sky One hd is showing on channel number 901. I don't know what's happened. On my box Sky Showcase hd I'm having the same issues as you channel 355. 900 is showing Sky One sd.
Message 3 of 5
According to Twitter it will be updated by the end of the day.
Message 4 of 5
Sky Showcase now working. No sign of sky max though.
Message 5 of 5
Both channels set up now.
