david1982
Message 1 of 3
Sky Sports in HD
I cancelled this from my package on 20 Nov, but have since tried to get it out back on with no luck. I'm told I can have it in SD but not HD. No one can tell me why. I have all BT sport's and Eurosport in HD and also the 4k UHD box.I had this box at start of October before I cancelled Sky Sports and now on 7 Feb by email I am being offered Ultrafast 1 and 2, so my line speed must be OK. I have been helped in the past by Gemma_ P or perhaps one of the Mods have some suggestions.
2 REPLIES 2
BT TV Expert
BT TV Expert
Message 2 of 3
Re: Sky Sports in HD
Hi @david1982
Sorry to hear you are having problems again. If you contact me your details via PM I can have a look for you.
Thank you,
david1982
Message 3 of 3
Hi Gemma should have sent a reply much sooner. Seems the answer is you must get Sky Sports SD and then you can upgrade to HD. You cannot opt to go straight to HD
