Michael1812
Message 1 of 2
Sky Sports not recording - help needed
Hi I had set up a recording for 12:30 am at 20/07 on Sky Sports main event for Toronto FC v New York. I just got up to watch it and it is still listed in my scheduled recordings even though it has already aired. If I scroll back through the guide it also had the red 'R' on the listing but I can't watch it.
Do you know what went wrong and how I can prevent this from happening again?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Sky Sports not recording - help needed
Hi @Michael1812 Sorry that the match didn't records for you.
Have you tried to record any further Sky Sports programs since and is it still happening. If so try Recording problems on BT TV and see if that solves the problem and post back to let us know.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
