jam2000
Expert
Message 141 of 540
Re: Sky sports rebrand
Really so your saying sky sports pictures are HD?
Alan-Brazil
Message 142 of 540
I said good/decent picture, i have noticed throughout this thread (and others) you are very negative towards sky/now TV, do you work for BT?
jam2000
Expert
Message 143 of 540
No. They state HD which it isn't.
Alan-Brazil
Message 144 of 540
720p is technically HD, if you aren't seeing that then there is something wrong with your setup.
Guru
Message 145 of 540
Going to give it a try via Chromecast.
Stew
ruth554422
Expert
Message 146 of 540
@MJH62 no you don't its possible to get sky sports in high definition without box sets 100%.
ruth554422
Expert
Message 147 of 540
Granted we had to phone up to be offered this mind. There website doesn't offer it as a matter of course.
jam2000
Expert
Message 148 of 540
Nothing wrong with my setup, Netflix, Amazon and 4k blu ray all work prefect and provide excellent picture quality.
scointer
Recognised Expert
Message 149 of 540
You are comparing quality outputs (1080p/4K) with poor mans HD (720p) so you will see the difference. NowTV does do ok HD but it all depends on your point of reference to if it will do or not. Your point of reference is high.
Hunter2660
Recognised Expert
Message 150 of 540
Personally I do not use Now TV, but stream non BT Sport stuff legally, (or legally grey), via another site. The quality of the stream is higher than SD (720p), but falls way short of true HD. I can't see how any unicast stream will match true HD without consuming massive amounts of bandwidth.
