Newbie
Message 1 of 2
Sky to BT - Tv Aerial
I have recently moved into a flat where there are some sky cables/aerial wires in place (previous tenant had sky) and an old style aerial point in the wall.
I connected my BT you view box using an old style aerial which I plugged into the point in the wall, however the signal is poor.
My question is, if I were to buy a connector for the sky aerial wires and plug into the BT You View box, is this likely to resolve my issue and improve signal strength?
Thanks!
1 REPLY 1
Message 2 of 2
Re: Sky to BT - Tv Aerial
No, that will not work, you need a terrestrial TV aerial signal, not a feed from a satellite dish.
You need to identify why the Freeview signal is so poor. Perhaps the aerial distribution system is faulty, ask the landlord.
