ab79
Message 1 of 1
Slow to no remote control response on my youview box.
My youview box has deloped a fault where there is no response or very very slow movements from the remote control. It works fine using the controls on the box itself but not the remote. I have changed batteries to no avail and its exactly the same from my universal remote control also.
I have turned off the box at the back but nothing seems to help. Can anyone suggest anything else. Thanks.
