Flossy744
Message 1 of 3
Slow to react
For the last couple of weeks, when pressing the remote control it’s taking a few seconds to react.
usually when going to something we have taped or any of the I player /ITV/channel 4/ and such like.
same when deleting a watched program.
Any  ideas as to why this is happening.
2 REPLIES 2
DavidM
Moderator
Moderator
Message 2 of 3
Re: Slow to react
Hi @Flossy744 and welcome back.
Sorry you're getting a delay when using the remote. I've had this problem myself. The remote was slow and unresponsive at times. I found changing the batteries helped. Can you try that and let me know if it makes any difference.
Cheers
David
Flossy744
Message 3 of 3
Re: Slow to react
Thank you, today my hubby switched it off and then back on again, at reboot it said there was an update, we did the update and I have also just this minute put new batteries in, so we will see how things go from now.
thanks again.
