GarethW
Expert
Message 1 of 4
So what is the pink screen fix?
I've changed the HDMI cable, turned on the TV and the box in various orders and it's still pink.
3 REPLIES 3
jam2000
Expert
Message 2 of 4
Re: So what is the pink screen fix?
What type of box are you using?
GarethW
Expert
Message 3 of 4
Ah! Unplugging the telly from the mains has sorted it.
Distinguished Guru
Message 4 of 4
The wonders of HDMI.  They started off with the DVI system used on computer monitors - which was technically poor in the first place, then at the insistance of the film companies added on a horrid and unreliable encryption system.
Unless the YouView box and the TV successfully start talking to each other when they both are switched on, it simply won't work.
