Message 1 of 4
Software reset!
Turned on my box today and was presented with the 'software reset' dialogue box.
What's happening? I now have to go through the whole pain of resetting up the box again.
3 REPLIES 3
Message 2 of 4
Re: Software reset!
@Caher
They do that occasionally I'm afraid. Once you've done options 1,2 or 4 there's not much setting up to do other than retuning the channels and resetting the volume, confirm deletion and repairing the app.
All recordings & scheduled recordings remain - the schedule is slowly picked up from the servers.
Message 3 of 4
Re: Software reset!
Unfortunately @Caher  if it is the same box that you experienced issues with series record of Frazier discussed in separate thread
https://community.bt.com/t5/YouView-from-BT/Cannot-series-record/m-p/2187838#M63869
it does look like the box has determined that issues now warrant a reset … possibly only the complete factory reset will cure although certainty worth trying the  partial resets that preserve recordings.
Message 4 of 4
Re: Software reset!
Yes it is and it will now series record again. Just that now I've lost all my recordings. I suppose I should be able watched them anyway!
