Newbie
Message 1 of 4
Software update crash
My box is currently trying to update and has been stuck on 40% for the last half hour. Does anyone know how long it should take please !? And what do i do!?
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Software update crash
@Fairyness82 I hope you don't mind I've moved your thread to the Youview board as I presume this is a BT TV problem?  Updates can take time but it should't get stuck like that, did it resume or is it still a problem?
Newbie
Message 3 of 4
@Neil0 thanks for moving it. I wasnt sure where i should post .
No it didnt resume at all after 2 hours. So i had to resort to turning the box off at the mains to make it work again. So box is still not updated
Moderator
Moderator
Message 4 of 4
Hi @Fairyness82,
Have you tried resetting your BT Youview box?
If not take a look at -How do I reset my BT TV box?
Try the first reset, as this will allow you to keep your recordings. Give that ago and let me know how you get on?
PaddyB
