ozsat
Expert
Message 31 of 63
Re: Sound echo issue on AMC Channel
@SeanD- this issue has returned
using Superfast Fibre 1 Unlimited with BT Max TV package (inc. UHD).
Moderator
Moderator
Message 32 of 63
Thank you @ozsat.
We're having this investigated for you.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Moderator
Moderator
Message 33 of 63
Hi all,
Can you check the channel now to make sure all is working ok for you? Any issues, please let me know.
DanielS
Kudos”
kinetic747
Message 34 of 63
Everything OK at the moment.
ozsat
Expert
Message 35 of 63
Yep - is ok now
KARL05
Newbie
Message 36 of 63
Yes Daniel, HD channel sound is back to normal. Thanks
adrian9595
Message 37 of 63
The problem is happening again
kinetic747
Message 38 of 63
Yes, same here. It's about time a permanent fix was found.
Philscarlet
Message 39 of 63
Same here, I’ve just switched to BT fibre from Sky and was promised that the multitude of technical issues and shocking support I experienced when I was with BT previously, was a thing of the past. Let’s see if I get beyond the cooling off cancellation period.
matkeir1408
Message 40 of 63
Mines doing this now. Not been a problem until I moved about 2-3 weeks ago. I thought it was my new TV initially. But its only on this channel and its really annoying.  Is it best to contact BT or Sky?
