Andrew600
Message 51 of 63
Re: Sound echo issue on AMC Channel
AMC is currently unwatchable because of the sound issue.....again!!
It strikes me as being pretty basic stuff. How does it keep happening?
Andrew600
Message 52 of 63
If it helps at all and in the unlikely event that anyone is interested in fixing it, apart from the incessant unbearable warbled audio, the centre channel content appears to be coming from the surround left speaker. I can’t tell what is going on with the other channels, but suffice to say  5.1 content is completely broken.
The warbling continues in stereo through the ad breaks.
The entire channel is a waste of space on the EPG at the moment.
It needs fixing fast. That’s three recordings I’ve had to delete as useless now. Not acceptable in any way, shape or form.
Kevin4
Message 53 of 63
I have this exact issue as well.
I recorded a movie on Saturday evening which is unwatchable, the channel still has this issue today.
As you say, totally unacceptable, maybe an email to the CEO of BT could get a resolution ?
markthg
Message 54 of 63
Yay! One year on, the first time I have used the channel since FTWD finished last season and the same damn problem is still there, great tech team work there BT!
same as last year, glad I’m blowing £39 a month on this rubbish.
fix it properly and permanently please!!!
Moderator
Moderator
Message 55 of 63
Hi guys,
Thanks for taking the time to report this.  I'm sorry that for the sounds issues experienced watching the AMC HD channel on Sky's platform.
I have raised this with our service team and they were able to replicate the issue.  They believe they've fixed it now.  Can you guys check and post back to let me know please?
Thanks,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
Andrew600
Message 56 of 63
@RobbieMac
Thanks. It seems to be fixed accessing via Sky Q. The movie on air at the moment is behaving itself.
Why does this keep happening though and why does it need us to identify that there is a problem? Surely someone should be monitoring every channel on a regular basis.
kinetic747
Message 57 of 63
Fixed here also on Sky HD. I'd echo the above comment, why does it keep happening?
B13blues
Message 58 of 63
A google of AMC sound issues brings a lot of problems going back 5 years.
Kevin4
Message 59 of 63
OK here on Sky HD too.
Artvandalay
Newbie
Message 60 of 63
This has been a recurring problem for the last few years. Recorded FTWD on my sky+ on Sunday and Monday and both were the same sound distortion- happened with The Terror too. Appalling that we pay so much money to BT and the sound problem persists. Please make sure you fix it -seen hundreds of customers complaining now.
