Stew37
Message 1 of 63
Sound echo issue on AMC Channel
I’m having this sound echo issue today on AMC. I’ve only just signed up to BT. Is this what I’ve got to look forward to?
62 REPLIES 62
JohnC2
Moderator
Moderator
Message 2 of 63
Re: Sound echo issue on AMC Channel
Hi @Stew37 Welcome to the forum and sorry you are experiencing a fault with the AMC channel. I've moved your post to create your own thread as that's the best thing to do.
Have you checked if the issue is also occurring on any of the other Internet based channels?
Cheers
John
Stew37
Message 3 of 63
Hi John, many thanks for the response.
It’s only on AMC HD channel. I’m a sky customer of over 10 years and never had any problems with sound, so I know it’s not a problem my end.
Many thanks
Stew
RobbieMac
Moderator
Moderator
Message 4 of 63
Hi @Stew37
Thanks for replying.
Are you getting the echo on the AMC channel SD channel also?  Nothing has been reported that I'm aware of. If it's only happening on the HD channel send us over your details and we'll ask the TV guys if there are any issues.
Click on my username here >> RobbieMac << and you'll see our contact link underneath my profile picture.
Cheers,
Robbie
Stew37
Message 5 of 63
Hello Robbie,
The SD channel is fine it’s just the HD channel. I imagine it must not be just me experiencing this, as I said never had something nd problems before.
Many thanks
Stew
zulu17
Distinguished Guru
Distinguished Guru
Message 6 of 63
Are you watching the channel  via satellite on the Sky platform or via broadband  on the Youview box ?
Stew37
Message 7 of 63
Hi, I’m watching via satellite. There’s nothing wrong with the dish or positioning, it’s not been changed.
Stew
andym1
Message 8 of 63
I have exact same issue. Switching on AD on the Sky Q box 'solves' the problem. But that also downgrades it to stereo so it isn't really a permanent solution.
Stew37
Message 9 of 63
I just have the sky+ Box. I changed sound options in the settings but that didn’t help. I’m sure it must be an issue with the channel and not anything my end. Who do I contact?
Macey6
Message 10 of 63
Same problem for me on a Sky+ HD Box. Very annoying!
