spandau
Message 1 of 4
Sound issues
The sound keeps going off on my box. The only way to restore us to unplug and reboot. Any suggestions. Cheers
3 REPLIES 3
gomezz
Recognised Expert
Message 2 of 4
Re: Sound issues
Are you using FF / REW on an internet channel recording? If so, that is a known bug and you need to use Skip instead.
spandau
Message 3 of 4
Re: Sound issues
Ah ok. I'm not sure when it occurs. Will check. Cheers
skappy70
Recognised Expert
Message 4 of 4
Re: Sound issues
I sometimes get loss of sound when changing channels, can't remember if it is from a terrestrial to IPTV chan. or vice versa. My normal fix is to toggle the HDMI output from 1080p to 1080i or 720p then revert changes when asked. Very occasionally do I have to reboot the box.
