barneys
Message 41 of 135
Re: Sound loss after fast forward
Was worth a try as the problem seems to only affect the broadband delivered channels.
gomezz
Recognised Expert
Message 42 of 135
After experiencing sound loss on MotoGP and rugby this weekend but *not on BSB on Eurosport I am further convinced that there is something different about a BT TV / Sport stream from a Eurosport stream that is triggering this bug in the firmware. Of course, the firmware should be robust enough to handle anything a stream throws at it.
barneys
Message 43 of 135
You could well be right. I admit I don"t know enough about the format of the streaming technology and whether it differs channel to channel. I have experienced the problem on some entertainment channels like Universal but as you say not on all sports channels. I thought it was random but maybe not?
gomezz
Recognised Expert
Message 44 of 135
Just for the record: Having now got 29.27.0 of the firmware I can confirm this bug has not been fixed in that.
gomezz
Recognised Expert
Message 45 of 135
More confirmation that this bug is only triggered by BT channel recordings. Been using FF on Eurosport 2 HD this morning to watch WSB and it has been fine.
seniorcitizen
Message 46 of 135
Just picked up this thread as am suffering from same issues. Happens to me when I fast forward at full speed (x30) recorded BT sport programmes. Agree using skip button avoids the problem. I have also tried restricting fast forward to x12 and this seems to prevent loss of sound as well. I see from gomezz post on 20 October that the forthcoming software update 29.27.0 won't solve the issue. Has anbody heard from BT whether they are treating this as a software fault or defective box?. I'm no expert in these matters, but it seems very odd to me that the loss of sound affects not only the recorded programme being FF (which I could understand) but the total loss of sound on the box even from live Freeview programmws.
Frankrh
Message 47 of 135
Personally, I think the issue relates to recorded channels that are streamed such as BT Sport, as I first experienced it when watching rugby, Indycar (ESPN) and moto gp highlights. As I don't watch many recorded streamed programmes I can't say how unreliable other streamed channels may be. However, I haven't seen the issue on catch-up services, even BT player or Freeview channels.  More regular uses of the youview box may have other experiences.  As you have experienced, once it happens sound on all channels is affected and in my experience only switching the box off and then rebooting it brings the sound back. I have mentioned before that pvr's often have a short sound gap when starting normal playback after FF or RW and it is as if the box gets stuck during that gap but video continues to play. What triggers that may be the key but it so intermittent it is difficult to pin down. Streamed channels don't FF or RW like normal channels and maybe something happens during that process. I have been using skip rather than FF and so far I haven't had the problem, but it needs sorting. I believe other boxes provided by other providers may have similar issues which points to s/w.
RevDave_50
Newbie
Message 48 of 135
I have experienced this problem for some time. Only occurs on BT programmes (BT Sport 2 in my case). The only way to get sound on any channel, including live TV is to do a hard reboot.
Is this a problem with particular YouView boxes?
C_Chadders
Message 49 of 135
I have this problem. I’m recording the daily Ashes Highlights on BT Sport 1 HD. Each time I’m starting the recording and then forwarding (either FF or skip, it makes NO difference) to the point of the action I want to start watching from... and NO sound when I press PLAY. No solution other than to reboot, which is a nightmare if I happen to be recording something at the time. I think this is a software issue as there is nothing else wrong with my set up/signal etc. It literally happens everytime - so basically I can’t FF/skip recorded BT Sport HD programmes. BT please patch this bug ASAP
newbluesfan
Message 50 of 135
Hi
i still get this problem. Has anyone solved this issue?
cheers
