BT TV Expert
Message 121 of 154
Re: Sound loss after fast forward
Hi @seniorcitizen,
Yes, the issue regarding erratic behaviour during skip forward/back is being investigated.
Regarding the connection to the internet being required for IP channel recording playback, this is due to the encryption of the video stream.
When you live tune to an IP channel, the set-top box joins the multicast stream and obtains the decryption key in parallel as it has to decrypt the video to render on the screen in real-time.
- When you record an IP channel, the set-top box simply joins the multicast stream and records it straight to disk without decrypting it. On every playback of an IP channel recording, the set-top box needs to obtain the decryption key from our platform to decrypt the content and render on screen. This is why an internet connection is required to play back an IP channel recording.
Hope this helps.
Gavin
Recognised Expert
Message 122 of 154
Not sure if I mentioned it before but my impression is that this only ever starts happening after both the record point and the play point have gone past an hour (eg 1:30 into an active recording of currently 1:45).  Which is possibly why it has not been commented on by more people as they tend to only watch programmes of one hour or less?
Message 123 of 154
Hi Gavin,
Many thanks for your helpful explanation. I can understand now why IP channels can suffer from the sound loss problem which doesn't apply to Freeview channels.
Regards
Message 124 of 154
Would this update also fix my sound loss after channel hopping or is this something completely different and unrelated ?
Message 125 of 154
Dear Gavin,
Further to your message number 119 of 28-01-2019,  I thought I should report that I suffered a complete loss of sound last night after doing a  REW (beacuse the backwards skip is only 15 seconds!) whilst watching a recording of the Liverpool/Leicester game on BT Sport.  Although this post only refers Sound loss after "fast forward" ,  I note that others have mentioned the same problem when doing a fast re-wind, so hopefully when testing your new "fix" you will ensure it works on re-winds as well.
Many thanks
Newbie
Message 126 of 154
I too have loss of sound when fast forwarding, it happened when I was watching a HD recording of Newcastle v Man City.
BT TV Expert
Message 127 of 154
Hi @seniorcitizen, we've tested the fix (including fast forward and rewind) and it looks good.
Will let you know when it's scheduled for release.
Gavin
Message 128 of 154
Hi Gavin,
That's great news. Look forward to the release date. Any chance you could explain in layman's terms vwhat was causing the problem?.
Many thanks.
Message 129 of 154
Turned my TV on yesterday - no sound and it didn't matter what I did this time it won't come back so maybe I have another fault - time to throw the 6 week old you view box in the bin.
You tube works fine from the TV so no issue there....
Message 130 of 154
Good job Gavin/BT... I was queitly confident that once this problem was investigated it would be quickly solved.
