Eddie9
Newbie
Message 1 of 4
Static noise on the Sky Sports Main Event HD channel
I have just started getting static noise on the Sky Sports Main Event HD channel without there being any of the normal sound. I do not have this problem on the Sky Sports Main Event channel (the channel which is non HD) or on any other HD or non HD channel. Any help would be appreciated.
3 REPLIES 3
Eddie9
Newbie
Message 2 of 4
Re: Static noise on the Sky Sports Main Event HD channel
I  turned the BT TV Set Up Box off, waited a few minutes and turned the Box back on.  The static noise has gone and everything is back to normal.
Moderator
Moderator
Message 3 of 4
Hi @Eddie9 Welcome to the community and thanks for posting, sorry about the sound problems I'm sure that's a right pain. Can you try a reset of the box ensuring to keep the recordings and let me know if that helps?
Moderator
Moderator
Message 4 of 4
Hi @Eddie9, Nice 1, I'm glad that sorted it.
