kartay0596
Message 1 of 9
Stressed and need help!!
I've plugged in my you view box and checked several times that everything is where it should be, but I can't get the coloured lines off my screen. Driving me mental 😝
8 REPLIES 8
gomezz
Recognised Expert
Message 2 of 9
Re: Stressed and need help!!
What coloured lines? Can you describe what you are seeing in a bit more detail?
kartay0596
Message 3 of 9
The screen has chunky coloured stripes on it. Nothing I do seems to work. I'm usually pretty good at setting stuff up but this is driving me crazy.
gomezz
Recognised Expert
Message 4 of 9
Around the edge or down the sides. Can you seen any picture at all or what?
Only thing I can think of is that it is an HDMI handshaking problem in which case things to try
1) Make sure the HDMI cable is securely plugged in at both ends;
2) Try a different HDMI cable;
3) Try cycling through the different screen resolutions your TV sets offers;
4) Set screen resolution on the TV set to Auto and try cycling through the different screen resolutions on the Youvie box.
kartay0596
Message 5 of 9
I've just bought a hdmi-usb connector as my old plasma doesn't have a usb slot..maybe it's that?
Distinguished Guru
Message 6 of 9
its an HDMI connection you need. not USB
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
kartay0596
Message 7 of 9
Yes I know that's what I meant. It's a hdmi to scart connector
4KMarty
Message 8 of 9
Is this on all channels or just the BT pay ones, i.e. those appearing from 300 and above in the EPG?
If it's just those, how have you connected the box to the Home Hub?
If it's all, then your HDMI to SCART converter is likely to be the cause
Whcih box do you have? If it's the recording box with the silver and black front then that has a SCART socket.
kartay0596
Message 9 of 9
I have the little you view box I'm going to try the converter on something else to see if it's that..if not I'm sending the box back as had enough now
