you might try a maintenance mode reset - this is something that can be tried prior to the loading of the Youview/BT software by invoking the maintenance mode menue . It is described at
There are various different levels of reset modes 2 (factory reset keeping recordings) . mode 4 (interenet reset keeping recordings) are the ones to consider.
