Fgillies
Message 1 of 13
Subscription channel unavailable
Got BT tv with phone and broadband in September 2017 , we are constantly on the phone as we can’t get our channels to work - been fobbed off with lame excuses - the message on screen says there’s a problem with your broadband which is affecting the channel . We’ve done everything to no avail , had an engineer out eventually last week who confirmed it was a broadband problem
!!! What do we do now ? We are so fed up with BT
12 REPLIES 12
Moderator
Moderator
Message 2 of 13
Re: Subscription channel unavailable
@Fgillies welcome to the community and thanks for posting, I'm really sorry to see you're having problems with your BT TV service.
How is your BT TV box connected to the broadband? Is it hardwired via ethernet or are you using powerline adapters?
Fgillies
Message 3 of 13
I am using power adapters supplied by BT
Moderator
Moderator
Message 4 of 13
@Fgillies Is it possible to connect directly with the long ethernet cable supplied with the box to rule out the powerline adapters?
Fgillies
Message 5 of 13
I will need to get back to you tomorrow if that’s ok, I will move tv directly beside the box
Thank you for getting back to me 😊
Moderator
Moderator
Message 6 of 13
@Fgillies No problem, that would be great if you could try that. I'll be here tomorrow and will keep an eye out for your reply.
Fgillies
Message 7 of 13
Hi, tried the tv direct with BT box and still can’t get the channels .
The engineer said the equipment was good and the problem was the broadband.
Moderator
Moderator
Message 8 of 13
@Fgillies Thanks for trying that anyway, if you post your router stats we'll take a look at the broadband side of things. Are you getting an error message or code when trying to view one of the subscription channels?
Fgillies
Message 9 of 13
HI Neil
Download speed 38.15
Upload speed 9.00
Ping latency 30.13
Test done at 12.55
Fgillies
Message 10 of 13
The error code at the moment is
IPC6002
