RonJ197
Message 1 of 3
Syncing capability
Does the HUMAX DBT2200 box have the functionality to adjust the sync between the picture and sound?
Certainly the HELP menu for the BT TV indicates the I should be able to adjust the sync in one of the settings sub menu but when I follow the link there is no option to make any sync adjustments.  BT engineer has been out but was not sure and thought the help menu was generic for all boxes and maybe the humax box could not be adjusted.  Does anyone have a definitive answer?
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: Syncing capability
@RonJ197 I don't have that particular Youview box model myself but I believe that assuming you are on the latest Next Gen  user interface that synch options can be found by
Youview > Settings > BOX MANAGEMENT Picture & Sound  > Synchronise Picture & Sound where there seem to be options to adjust in 20ms steps
RonJ197
Message 3 of 3
Thanks for the response but there is no option in the menu to sync, only to adjust the HDMI display and sound.  BT "technical" support and engineer were no help.  Cheers
