Natty75
Message 1 of 5
T2100 problem
Hi.we bought a 2nd hand you view box around 5wks ago.its been working perfect until today..the red light is on at the the front of box but nothing else is happening now.. we've had all cables out,unplugged,restored factory settings,maintenance mode etc..my hubby changed it to smart mode,its gone wrong since then! Internet connection is fine,just can't get blue light to come on the box.has anyone got any advice please.. thanks.
4 REPLIES 4
Distinguished Guru
Distinguished Guru
Message 2 of 5
Re: T2100 problem
@Natty75 are you able to enter mainternance mode now ?
Natty75
Message 3 of 5
Re: T2100 problem
the red light is on at the front..I've tried turning it off at the back again etc but nothing happens.think it's ready to be thrown at a brick wall😂
TimCurtis
Recognised Expert
Message 4 of 5
Re: T2100 problem
Leave it off and disconnected from the power supply for quite a few hours, like overnight & see if that makes a difference.
Natty75
Message 5 of 5
Re: T2100 problem
I unplugged it all last night..will try and reconnect it all soon.thank you😀
