notoriousdbp
Recognised Expert
Message 11 of 13
Re: TNA Impact
Same again this week. 16th of August edition not shown in the TNA section but if you search TNA HD there it is
---Remember to mark as 'solved' and give stars when you like a post---
GarethW
Expert
Message 12 of 13
Re: TNA Impact
I didn't even find it when I searched! You have to type, 'TNA HD' as it doesn't appear if you type, 'TNA'.
Last week's is still not listed in the menu. Is this a YouView problem, or can you not (easily) access them the BT Vision box either?
Distinguished Guru
Distinguished Guru
Message 13 of 13
Re: TNA Impact
On Bt vision - you seem only to be able to access Sd & Hd versions of TNa impact by searching on TNA
They do not appear under the Sport  TNA channel.
Clearly whoever is loading them is not assigning them to the correct channel category.
That is a recurring problem that BT Vision has had for over a year (ie since they introduced the new look interface) - it occured regularly with films in the past.
