Has anyone got the TVAV button working with a Philips OLED? Pressing the button brings up the input menu on the TV (good), but then there is no way to navigate to the desired input (bad).... On my old Sony repeatedly pressing the button did the trick, the Philips needs you to cursor down (or up). From what I can see, it isn’t possible to get the YouView remote to do this?
And while I am at it, its a shame the YouView doesn’t support HDMI CEC - That could resolve a lot of issues, not least of which the awful remote!
I have the same problem, i've tried a lot of remote control codes and while on some I can get the AV input menu up, I cannot navigate - the arrow keys do not function or they act like Programme up/down. It is driving me nuts.
Just keep pressing the AV button , that should just take you to the next input each time you press it.
Alas, it just cycles the AV menu on/off.
Maybe it's a code problem. What's the make of TV?
Hi
It is a Philips 8000 series,
I appreciate the time you are taking looking at this for me.
Michael
