Cathis
Newbie
Message 1 of 3
TV app
When I use the app and want to set a recording, it always says request sent but then never records, any reasons why this is?
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: TV app
@Cathis sorry about that, have you tried deleting then reinstalling the app again?
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
srpsrp
Expert
Message 3 of 3
Re: TV app
Does you mobile device show up in the list of devices in settings ? I had to reset my box once and it didn't tell you that you needed to re-register all your mobile devices and you couldn't tell form the app it was not registered either. That was the old vesion of the app though so not sure if it's still the same now.
