Dandan56
Message 1 of 4
TV guide not showing my now channels
I have tried to reset the box and a d rwtune channels it says 128 subscription channels but not is showing in the TV guide
Any helpers?
3 REPLIES 3
NigelB72
Guru
Message 2 of 4
Re: TV guide not showing my now channels
Check the EPG settings to make sure no channels are hidden
zulu17
Distinguished Guru
Distinguished Guru
Message 3 of 4
@Dandan56  Try restarting the BT Tv Youview box by holding the front button for 8 seconds or so  and see if the channels appear after the restart.
PaddyB
Moderator
Moderator
Message 4 of 4
Hi @Dandan56,
Welcome to the Community and thank you for posting.
@NigelB72 suggestion about the hidden channels is a good starting point.
To check for the hidden channel
  • Go to the TV guide, then press the YELLOW button on your remote
  • Enter your YouView PIN
  • Press the RED button (not the red 'R' button for recording) and this will restore any hidden channels
You can find out more here - Missing Channels
Thanks,
Paddy
