gavlala
Newbie
Message 1 of 5
TV guide
My TV guide is black background with white lettering/numbers. Is this correct?
Also, does anyone know why the guide sometimes goes too big for the screen, is this dependant on which channel you select, it is highly annoying!
4 REPLIES 4
Bluemoon1
Message 2 of 5
Re: TV guide
There should be a choice under the settings to change the look of the TV guide. Also the guide can change to look to big for the screen if you are on a channel showing something that has been stretched to fit wide-screen eg sometimes on UKGold does it .
gavlala
Newbie
Message 3 of 5
Re: TV guide
Cheers, can’t find anything in settings to change view, but thanks for the info on screen size, makes sense.
Bluemoon1
Message 4 of 5
Re: TV guide
To access settings press the blue youview button scroll right to settings press ok go down to accessibility & languaage scroll right to Appearance click ok and the toggle for HIGH CONTRAST COLOURS should be OFF transparent backgrounds set to ON channel logos set to ON . When done highlight done and it should be set to the normal guide.
gavlala
Newbie
Message 5 of 5
Re: TV guide
Nice one, thank you.
