EP1942
Newbie
Message 1 of 4
TV problem
Every few seconds my TV turns itself off then on repeatedly. When on both sound & vision are OK.
It comes back on to HDMI followed by picture & sound. A few seconds later it goes off again. Repeatedly.
I have tried unplugging at mains, waiting a while then plugging in again, allowing BT VIsion to reload, but same problem continues every time.
TV is Samsung
3 REPLIES 3
gomezz
Recognised Expert
Message 2 of 4
Re: TV problem
Does it do this if just watching TV using the built in Freeview tuner rather than using BT Vision?
EP1942
Newbie
Message 3 of 4
Re: TV problem
I dont know, but yesterday I phoned BT Techs & having done a general test they said it was a
BT Vision box fault. The BT Vision box is very old & they are sending me a new one which hopefully will arrive tomorrow. I just hope I can set it up as they wont send anyone to wire it up for me.
Moderator
Moderator
Message 4 of 4
Re: TV problem
Hi @EP1942  If you have any problem with setting up the new box here's a Video that should help you. Post back and let us know if the new box has fixed the fault.
Cheers
John
